meritez
The MikroTik Chateau LTE has six antenna connections, two external and four internal, as pictured below:
In the default hardware configuration, only MAIN_EXT and DIV_EXT are connected to external SMA ports.
As you can also see, the Chateau LTE only has 4 total antenna connections, DIV, MAIN, MIMO1 and MIMO2, which makes Router-Mods Six external antenna mod pointless:
router-mods.co.uk
Anyway, to save £75, and use the pre-existing holes, I will need 4 antennas, and 2 ipx to sma cables.
I can then connect the MIMO1 and MIMO2 externally
MikroTik Chateau 4G LTE12 Router Modification Service
router-mods.co.uk
