Monitor display from Laptop Wrong Size
OldGeezer
Hi all
So I have a Dell Laptop connected up to an old AOC monitor with a vga/hdmi adaptor.
The display on the monitor is wrong as it doesn't display the taskbar at the bottom or part of the right hand side of the screen.
I have tried changing a few settings, resolution but to no effect :-(
Any ideas?
kommando828
Try looking for a driver for the AOC, even if you find one it will be old so you will need to force it to be used.
Johnmcl7
It sounds like overscan which is quite normal to see on a TV but not on a monitor although may be worth checking anyway. On the monitor itself check to see if there's a setting for the picture size or aspect ratio with options like 4:3. 16:9 etc. and cycle through them to see if there's an option like just scan or similar. If it's not in there have a look through other entries in the display settings to see if you can find something similar.
OldGeezer
Thanks for the advice fellas. I did try changing the adaptor setting to 59hz then back to 60hz. Just gone back to try it out and now I'm just getting "No Signal" :(. Might have to try and pick up a cheap Monitor with HDMI, that should solve the problem.
Lucian
Yeah, it's full of old working monitors online, check ebay, Facebook marketplace, nextdoor etc
OldGeezer
With it being a newish Dell Latitude 5420 Laptop could it be that the hdmi to vga converter needs some power to work?
I use a dell power bank with lots of different connections and a cable from that (bit bigger than HDMI) to a converter then into vga monitor and that works fine.
Confused dot com
Pheasant
Ahh good old VGA!
Unless you can tweak the position / size on the display itself - think you’re on a bit of a hiding really.
Could try another converter, but it’s probably more good money down.
Pheasant
So it works with *another* VGA converter - but plugged into a non-HDMI (DisplayPort ?) port?
timeless
Staff member
Volunteer Mod
OldGeezer
Thanks for the advice but my needs are the opposite way around.
Laptop HDMI OUT into a VGA Monitor.
  • Hyperoptic £17.99
    Speed 33Mbps, Unlimited
    Gift: Promo code: BIGBANG
  • Shell Energy £20.99
  • NOW £22.00
  • Vodafone £22.00
  • Plusnet £22.99
    Gift: £70 Reward Card
  • Gigaclear £17.00
    Speed: 200Mbps, Unlimited
  • Community Fibre £17.99
    Speed: 158Mbps, Unlimited
  • Vodafone £25.00
  • Virgin Media £27.00
  1. FTTP (4221)
  2. BT (3183)
  3. Politics (2152)
  4. Building Digital UK (2042)
  5. Openreach (1998)
  6. FTTC (1931)
  7. Business (1872)
  8. Mobile Broadband (1632)
  9. Statistics (1525)
  10. 4G (1400)
  11. FTTH (1372)
  12. Virgin Media (1302)
  13. Ofcom Regulation (1252)
  14. Fibre Optic (1247)
  15. Wireless Internet (1246)
  16. Vodafone (940)
  17. 5G (926)
  18. EE (922)
  19. TalkTalk (832)
  20. Sky Broadband (795)
