monitoring
PCR
0
Wasnt sure where to put this question, so stuck it here! if anyone wishes to point me in another direction then feel free.
Anyhow, yesterday i connected up my next door neighbours to my router (good luck to them i say with my current problems!!), because im a kind soul, and they cant get a phone line into their house, so because we are connected to the same building it was easy to shove network/cat5 cable thru the ceiling, through the loft and down into their house. anyhow, main question, id like to monitor how much usage they use from my end, but my router doesnt really help that much in that regard. ive set up quality of service, limiting (i think), how much they use, but id still like to hopefully keep track of their usage. is there any way of doing this ? any utility that can monitor my routers/ip numbers and tell me how much in actual bandwidth and actual downloads/uploads they are using.
again if theres a more suitable place for this question please move it
thanks in advance. :)
You might get more help in the computer hardware and software forum I used PRTG once might be worth a look.
belongs as they don't do anything like bomb making, child porn, or download tonnes of copyrighted P2P stuff ... then nothing bad should come your way - just beware that if they did anything, the authorities will be knocking on your door, not theirs . . .
