More latency issues with Vodafone (Lebara)...
kocz
Using a Lebara unlimited SIM for 4G broadband.
Every once in a while, my latency seems to shoot up from ~30ms to >150ms, typically lasting from a few hours to a couple of days. The speed also seems to be affected somewhat too, as it jumps around all over the place instead of being constant like it usually would be. I've only experienced it a couple of times, but it makes any kind of gaming or realtime activities impossible.
I ran a tracert which confirms it's not on my end. Is anyone else experiencing this right now, or is this just a local mast or citywide fault? There's nothing out of the ordinary showing up on the VF status checker page, which might be expected as it technically does sort work.
Code:
Tracing route to bbc.co.uk [151.101.0.81]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  homerouter.cpe [192.168.1.1]
  2     *        *        *     Request timed out.
  3    36 ms    40 ms    38 ms  192.168.213.21
  4   135 ms   133 ms   110 ms  192.168.213.22
  5     *        *        *     Request timed out.
  6     *        *        *     Request timed out.
  7   123 ms   133 ms   139 ms  63.130.127.213
  8   121 ms   120 ms   119 ms  90.255.251.103
  9   135 ms   136 ms   146 ms  151.101.0.81
kocz
Seems to have fixed itself since last night or this morning, and it's back to normal. Would be good if this didn't have to happen every few weeks though.
Code:
  3    43 ms    41 ms    46 ms  192.168.213.21
  4    39 ms    43 ms    36 ms  192.168.213.22
  7    49 ms    43 ms    47 ms  63.130.127.213
  8    45 ms    37 ms    52 ms  90.255.251.103
  9    47 ms    47 ms    36 ms  151.101.0.81
kocz
Aaand the faults back again. This time it's being very volatile between 40 and 90ms, instead of a constant 140.
kocz
Do you notice a change of public IP?
I'm honestly not sure, I haven't been tracking it. It changes every now and again, usually lasting a couple days, but obviously the IP is shared. The "WAN IP address" on the router page is showing as 10.165.163.132 - again, no idea if this is typical.
which APN are you using?
uk.lebara.mobi / Lebara Internet
meritez
web browsing to http://uk.lebara.mobi takes you to cloudflare, and a 1001 dns resolution error?
Code:
ping uk.lebara.mobi
Pinging m.lebara.co.uk.cdn.cloudflare.net [104.16.21.167] with 32 bytes of data:
any chance you could try the underlying m.lebara.co.uk.cdn.cloudflare.net apn?
kocz
Code:
ping uk.lebara.mobi
No idea if I cocked something up, but replacing that string completely disconnects the internet (and crashed the router for 15 mins... though I think that's an issue with the firmware).
maninman
do check out the public ip you're on - it indicates which Internet Exchange you're connecting to - London, Manchester or Edinburgh.
kocz
Current IP is 185.69.145.1, though the issue seems to have vanished again and pings are normal. Surely the exchange itself wouldn't make such a big difference? I've had pings to US servers below 80ms before (on fixed line), so an additional 110ms would surely still indicate a fault?
  • Hyperoptic £17.99
    Speed 33Mbps, Unlimited
    Gift: Promo code: BIGBANG
  • Shell Energy £20.99
  • NOW £22.00
  • Vodafone £22.00
  • Plusnet £22.99
    Gift: £75 Reward Card
  • Gigaclear £17.00
    Speed: 200Mbps, Unlimited
  • Community Fibre £20.00
  • Vodafone £25.00
  • Hyperoptic £25.00
    Speed: 158Mbps, Unlimited
  • Virgin Media £27.00
  1. FTTP (4204)
  2. BT (3181)
  3. Politics (2149)
  4. Building Digital UK (2042)
  5. Openreach (1995)
  6. FTTC (1931)
  7. Business (1866)
  8. Mobile Broadband (1630)
  9. Statistics (1525)
  10. 4G (1398)
  11. FTTH (1372)
  12. Virgin Media (1301)
  13. Ofcom Regulation (1251)
  14. Fibre Optic (1246)
  15. Wireless Internet (1244)
  16. Vodafone (940)
  17. 5G (923)
  18. EE (920)
  19. TalkTalk (832)
  20. Sky Broadband (795)
