Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
so doing some digging, my next door neighbour can apparently order fttp as the pole they installed the cbt on last thursday is now live, im served on the next post up which hasnt been done, frustrating. why dont they do them all at the same time, like i say they have wirec coming out from the ground on the poles im guessing ready for a cbt to be attached
i think these are virgin, they have been doing work down acre moss last few days and now these have turned up taped halfway down the pole, same size as them empy brackets that are taking up the top of most polesWhat’s this?
When was your date?My date has been pushed back... not suprised but its not too far out.
T
You may be lucky... tbh this is BT and OR so easier to put a bet on the wheel in a casino than visits going as planned.My date is the 14th, Do you think it will be pushed back or would’ve been done by now?
Remember there is no way of using/accessing BT Digital Voice without using the BT SmartHub. You cant use your own SIPbased soft phone/ATA/ etc.Got the DECT adaptor as I do not use the landland now... plan is to put it in to my server and deliver calls via SIP just so they get to us.
how long was the install process? was the ont placed where you wanted? or where it was easier for them?Installation went well.
Shitty Sky hub is the bottleneck now.
Getting 150mbps on Wi-Fi and 950 on cat 7.
2 hours.how long was the install process? was the ont placed where you wanted? or where it was easier for them?
cool, sounds painless really, the other houses that cant get fibre yet here have all sent questions to openreach to find out why, although with the strikes incoming not holding out much hope for response2 hours.
The ONT was placed where my MS was, We decided to remove the copper cable too.
I asked if I could put the ONT upstairs on the 1st floor but he said it would be an easier process if it was on the ground floor. Could’ve been done though.
He was a really nice engineer and was easy going to questions
