Mac
0
My stats are usually this :
DSL Status: UP
DSL Modulation Mode: GDMT
DSL Path Mode: FAST
Downstream Rate: 1696 Kbps
Upstream Rate: 448 Kbps
Downstream Margin: 8 db
Upstream Margin: 15 db
Downstream Line Attenuation: 63
Upstream Line Attenuation: 31
Downstream Transmit Power: 0
Upstream Transmit Power: 0
But when I use my phone this happens:
DSL Status: UP
DSL Path Mode: FAST
Downstream Rate: 0 Kbps
Upstream Rate: 0 Kbps
Downstream Margin: 2147483644 db
Now my stats have reset to this :
DSL Status: UP
DSL Path Mode: FAST
Downstream Rate: 1408 Kbps
Downstream Margin: 9 db
CAn anyone help? Is this a BT or ISP issue? I have put a new filter on the line and it is plugged in to the master socket.
DSL Status: UP
DSL Path Mode: FAST
DSL Status: UP
DSL Path Mode: FAST
DSL Status: UP
DSL Path Mode: FAST
