otester
0
I have two routers...
First provides the networks wireless capabilities, has UPnP and NAT options.
Second is the outter router providing the first with internet (2nd DMZ's the first), this also has the two options.
On MSN it can loose connection sometime and my connection overall is quite unstable, doesn't perform to well on Ares etc. (No firewalls installed etc.).
"You have a UPnP symmetric NAT" - basically an error with the triangle yellow !.
Any ideas on what configurations to use in regard to UPnP/NAT settings?
Also on my ISP settings (on their website) it says NAT is enabled, could this be the problem? Do other ISPs always use NAT? (I was with Fast4 before).
