Need help setting xbox up and toob router what setting to i play with or input ?
ukroy
Hi everyone i had to pay for there ststic ip address but thats asfar as i got with zero help from toob and i need to setup my sons xbox just need to know what to do or add on the router have tryed to put in there static ip address into the xbox nut no joy 😥
It should just be a case of either 1) connect the Xbox to the one of the Ethernet ports on the Toob router. Or 2) connect to the WiFi.
Your Toob router will assign the Xbox a local LAN address, traffic out to the internet will be handled by your router using the static IP address Toob have assigned you, it should not be required to enter this Static IP address anywhere on the Xbox.
IIRC the Toob router has UPNP disabled by default (as it's a bit useless without a public/static IP), so enabling that should handle any port forwarding required. But as Gunny said, your Xbox should just be on default network settings either wired/wireless.
FYI - I don't think you need the static IP. I don't, and I've not had any online play problems.
Caveat there is I don't play online much at all, but the few times I have it's been fine.
The main thing I've noticed is under the Network settings the Xbox will report 'Strict / Double NAT' but as soon as you run a Network test it says everything's fine and your NAT type is Open. I believe this has something to do with it using IPv4 to gather the basic network info it initially reports.
