Need help using a landline phone over VoLTE on 4g router.
4Gee
I have a Tenda 4G689 V2 4g router and I've tried both a Three and a Vodafone sim in it. Neither sim gives me a working "landline" when plugging my landline phone into it. The router is enabled for VoLTE but I'm unsure as to what type of phone I can plug in. I've only got a cheap, normal push button landline phone and I plugged that in using the cable supplied with the router. But for both sims all I get is a dead handset, no dial tone etc, just unconnected deadness.
Do I have to use a certain type of phone or is there some other settings or whatever I need to do.
Would appreciate some help.
TIA
The Tenda web site only gives the most basic specs for this router, and says a 'telephone' can be plugged into the phone socket for voice calls. There's no information about logging into the router to change settings, but presumably there must be a way.
With a working SIM installed try logging into the router at 192.168.1.1, or 192.168.0.1 to access the set up. ('Gateway address') . Some use 192.168.8.1
You can find the router address by right-clicking the Wifi or ethernet connection, see pic.
Some phones/routers need a reverse wire RJ11 cable, but I don't have further details.
Hi Verita, thanks for the reply.
Yes, I'd already accessed the router setup page but there's no obvious "enable VoLTE" type of setting. The reverese wire RJ11 is interesting but I would have thought the RJ11 cable supplied with the router would be the right one to use. Not sure. The complete deadness of the handset when plugged in though might indicate it's a cable problem of some sort.
There's a wiki entry on the peculiarities of 'British' phone wiring and the occasional neeed for reverse cables on some handset/routers, Amazon has them if you want to try.
Certainly I needed one to connect my fax machine to a VOIP/SIP adapter, but other than that I have no further suggestions.
It would be handy with a 4G router and a SIM with unlimited voice calls though, so please update if you get the blighter to work.
For voice calls here I relented and installed a couple of Grandstream SIP phones over ethernet and powerline adaptors (with Sipgate Basic) - the advantage being you can put handsets anywhere in the house with a spare mains socket.
No more landline fees is the extra bonus. :-)
OP,
If this Tenda router has VOIP/VoLTE functionality built-in, then there must be a way to configure the voice settings on the router. Otherwise the only other thing I can suggest is using a VOIP ATA adaptor such as a Grandstream HT801 to connect the bog standard phone to the router - you simply enter the VOIP line settings on the HT801 and then plug it into any spare LAN port on the router.
Hi, assume you mean the 4G680 as i can‘t see a reference to the 4G689 on Tenda’s website. If so I have one of these and can confirm the following...
There’s no VoIP functionality in the unit itself.
VoLTE is supposed to be implemented, but UK network support for it is generally currently often limited to certain network supplied handsets/custom firmware/tariffs. It didn’t work on either O2 or Three for me. I used PAYG sims that had both voice and data enabled.
However, fall back from 4G to 3G/2G for voice calls does work, and provided the unit is on the network, a correctly wired phone will provide a (non UK standard) dial tone when the handset is lifted, and the phone will ring (again non UK standard) if the number associated with the SIM is called. Whilst on a call, data transmission is usually slower, so simultaneous calling and streaming may not work too well.
The three PAYG SIM is ideal for testing with calls at 3p/minute, texts at 2p each (the web interface of the router allows text send/receive) and data at 1p/Mb. Obviously once proven, a PAYG SIM with a bundle or a contract SIM would be better for regular use.
Your lack of dial tone suggests that, provided the handset is known working on a landline socket, then you need an RJ11 plug to BT631A socket adaptor.
However, if you have a spare ADSL plug-in filter you can use this as a temporary makeshift adaptor. The filter has a BT style plug, sometimes on a short cable, and two sockets, one RJ11 usually labelled “DSL” “ADSL” or ”Router”
and the other, a BT style socket, labelled “Phone” or with a phone symbol.
Step 1: If the filter is already plugged into a phone socket, disconnect it and anything else plugged into it. YOU MUST NOT CONNECT THE BT PLUG TO ANYTHING whilst you are using the filter as a makeshift adaptor. It’s a good idea to put a bit of sellotape, masking tape or electrical tape around the unused BT plug to prevent inadvertent electrical contact in operation as you may get bit of a tingle, especially if the phone is ringing. Definitely keep inquisitive pets and children away from the set-up!
Step 2: Plug your landline phone into the BT socket on the filter, using the normal cable that came with the phone, and the (grey) cable from the RJ11 phone socket on the router to the RJ11 socket on the filter. Photo below shows how. Note the bit of tape around the end of the BT plug on the filter .
Step 3: Turn on the router. The phone should not immediately ring or make any noise. If it does, then something is wrong. Turn everything off, disconnect it and do not continue. If the phone has a line powered display, that may come on once the router is fully started up.
Step 4: Verify that the router has connected to the network (internet light on, and at least 1 bar on the signal strength meter) Check by connecting to the router wi-fi and browsing.
Step 5: Pick up the handset, you should hear a continuous dial tone, which is higher in pitch than the normal UK landline. You can now try dialling a number. Remember that this is a mobile call so the area code must always be used. The router only supports tone dialling, so if you don‘t hear the tones when you dial, then switch the phone to tone dial, or connect a different phone.
The number you called should ring, and both ends should be able to hear each other. There may be a longer than normal delay between finishing dialling and the other end starting to ring. This is because the mobile network expects the whole number in one go (i.e. on a normal mobile handset, you enter the whole number before you press “send” ), so the router has to wait a few seconds to see if you are going to dial any more digits before it initiates the call.
Step 6: Hang up and return the call. The phone should ring with a single ring.......ring cadence, not the usual UK ring..ring......ring..ring pattern. If the phone has caller ID, this may work, but as again it’s not UK standard then some handsets won’t display it.
If all of that works, then go off to Amazon/Ebay and get a proper rj11 plug to BT socket adaptor. Get one with a ring capacitor otherwise some older phones won’t ring on an incoming call.
If not, post what does/does not work, along with a photo of how it’s wired up and I’ll try to help.
Hi swt1963.
Thank you so much for the detailed response. Yes, it is indeed a 4G680 V2, exactly like the one in your pic. I got it for £40 off Amazon and negotiated a £10 refund because they sent me the model V2 rather than the model V1 I had ordered. Sweet!
I never thought I'd find a use for all the old ADSL filters I have but now I do. So I wired it up exactly as you state and lo and behold I have working VoLTE, all working exactly as you described. I used a 3 sim with free 200Mb per month on it and a Vodafone sim which had loads of data on it. Both worked in the router (but the Vodafone default APN settings are wrong, they have to be changed). Sincerest thanks for that ingenious fix.
To be honest, unless there's a good reason to not use an ADSL filter for this purpose I'm going to just keep to that rather than shell out on another lead.
If you have or know of any other general info with regard to the router itself that would be welcome. As you probably know the router only comes with a quick start guide and there's no in depth info!
Thanks again.
Glad the fix worked! There’s no real reason to stop using the filter, as long as you are aware that there’s a few tens of volts present at the pins of the redundant BT plug. Not really dangerous though. Good going on getting it for £30. I thought I was doing well at £40!
I did look on the tendacn.com website, but apart from a couple of firmware versions and a data sheet that gives no more real info there’s nothing. I guess that it’s a case of playing around with the device to see what things do. I might try a firmware upgrade if one of those on the website is later than what is installed already
Three must have enabled their “Supervoice” VoLTE service in my area in the last couple of days, as now the three SIM doesn’t fall back to 3G for a voice call. The O2 SIM still does, and if you lock the router to only using LTE you get an “engaged” type tone if you try and dial out.
Next step for me is to change the APN for three to ’3internet’ so that I get a real IP address instead of a CGNAT one, and then try my existing VOIP setup on this router instead of the one on the landline broadband. That will give me an 01xxx... number for those that insist on having a “landline” to call in on as well as an 07xxx... number to use the unlimited minutes that tend to come with the data bundles these days.
Cheers
Steve
Thats awsom Steve, I want to do exactly that... But the Tenga Router I got from Amazon was very poor at picking up a signal. At the moment I have an EE Mini Mifi attached to a TP-Links Router with a USB port that allows me to connect at pretty good speeds (20MBs Up & 10 Down) but I want to make calls on the SIM too. This can only be done with a VOLTE router... Any others or is there a setting to increate the signal on the Tenga? It was using the same SIM in the exact same position as the EE rMifi device... But the download was less that 3Mbs... Also, it kept disconnecting both from 4G & Wifi...
Any ideas?
The Tenga was the 3rd router I tried... First was the Huawei B525, Then the B535-235 and then the Tenga. All faired similarly... The B25 being the best of the bunch
Also is it somehow possible to use inclusive minutes using the mifi/TP-Links Router?
Hi Steve,
did I understand you correctly - you managed to use the VoLTE mode with the Tenda 4G680 V2 (is it this router:
) and with your Three simcard?
Or are you talking about another device, maybe a smartphone?
I am very interested in a 4G router that is able to use the VoLTE mode with the connected landline phone - not only Circuit Switched Fallback (CSFB) with 3G/2G mode during voice calls.
Cheers
Steve
Hi Steve, I sorted my problem before I saw this thread, here's what I did, bit long winded but here goes. I have a Huawei B535-235 4g router with phone socket(rj11) the router is unlocked for worldwide use with an active sim, I'm in the UK so tried a Smarty sim(owned by 3) data no problem, calls in and out didn't work. If you buy a phone from say Virgin mobile and a sim the phone is locked to Virgin, this the same for any phone bought from a mobile supplier regardless of who they are so the APN settings are coded to the phone(locked) but an unlocked phone is "unlocked" to any active sim card, now most unlocked phones have a small inbuilt APN file so when a sim is put in the phone the system knows what carrier the sim is from and looks up the APN details and the phone bursts into life, or your sent a text, now with an unlocked router as mine is the data base of APN's is limited as it's open for worldwideuse..so how I fixed my problem...I ended up using a Voxi sim(Vodafone) but had to change the APN in the settings menu to pp.vodafone.co.uk to make things work, with the Smarty sim(3) I had to change the APN settings from 3internet to
mob.asm.net so my advice to everyone is look up the apn settings for a android phone and apply them to your router.
I have a monthly contract with Voxi(Vodafone) but the APN that worked(pp.vodafone.co.uk) is for a Vodafone p.a.y.g sim, strange but it works.
llamedos46.
Hi has anyone been able to get their phone to ring? I can make calls no problem but when I dial the phone I receive an answer phone message the router is as above B535-235 4g router with phone socket(rj11) the router is unlocked for worldwide use
I had real problems getting incoming calls to work on my B535-235 when setup for VOIP with sipgate basic as they just went straight to voicemail. I moved over to an external Grandstream HT801and had the same problem, but finally solved the issue by moving the VOIP adapter into the DMZ on the router, so clearly the routers firewall was causing problems. This isn’t ideal as the VOIP adapter is exposed directly to the open internet so I will have a fiddle with the port forwarding over Christmas
With the Tenda 4G680 there is a problem with using a DECT phone. When 4G is selected the phone doesn't work. With Auto the phone does work but the internet connection is slower. A minor issue and saves getting a VOIP number plus for £16 per month with ID Mobile you get unlimited data and phone calls. Better than my current ISP!
