No hidden menu ZTEmc801a please help
Spudders87
Hi there just got myself the mobile router and for the life of my cant access the hidden menu to enable my external antenna on my roof when i put the address in it reverts to the home page? any idea whats going on i can only get 4g in my home but have a very strong 5g signal outside
My firmware is B15
If its the three version then you are out of luck i'm afraid, they removed it, only way you will be able to get the hidden menu is to buy an non three version from like aliexpress or somewhere else.
It has a large 3 symbol on the front of it! why disable such thing when its there to use.... Absolutely gutted!
Think im going to have to iv got this zte junk and a nghthawk m1 gathering dust now
What kind of hidden menus are you after? I have a script which allows me access to band lock, cell lock and signal stats. Also allows me to change the DNS.
