Onestream settings
k1s
So Onestream's intro email gives me PPPoE username and password and says I need to set VLAN to 101 but nothing else.
The router I'm using (as an ADSL modem only) is a Tenda D301 v4.0 (installation guide)
Does anybody know what I need to select for:
LLC or VC-Mux?
VPI: ?
VCI: ?
Enable NATP ?
Enable IGMP ?
802.1P: (0-7)?
(Also if anyone knows how to get that modem to set Auto/DHCP WAN IP?)
Onestream don't use ADSL Technology at all unfortunately.
Even if you're on their standard 17-20Mbps package, this is actually just a cut-back FTTC Product.
You need to get yourself a VDSL2 Compatible modem or router, or contact them to provide you with one at a small monthly cost.
  • Like
Reactions: k1s
I question the instruction to set the WAN interface to VLAN 101 rather than use the default VLAN 1, I could be wrong but that seems to be CityFibre specific, and as anything xDSL isn't CityFibre it doesn't seem right?
What I would be trying is
Reset to factory defaults
Set WAN to use PPPoE auth
Provide the PPPoE username and password
Save
Try that.
If there is a firmware upgrade available from the manufacturer get that installed but it's not critical to get you going.
CityFibre is 911, Openreach is 101
But none of this matters at the moment as the model that OP linked is specifically listed as an ADSL Only modem, and anything Onestream DSL is exclusively VDSL2.
  • Hyperoptic £17.99
    Speed 33Mbps, Unlimited
  • UtilityWarehouse £19.99
    Speed 35Mbps, Unlimited (FUP)
  • NOW £23.00
    Speed 63Mbps, Unlimited
  • Vodafone £24.00
    Speed 73 - 82Mbps, Unlimited
  • Shell Energy £24.99
  • Gigaclear £15.00
  • Zzoomm £19.95
  • YouFibre £19.99
  • Community Fibre £21.00
  • BeFibre £21.00
    Gift: £25 Love2Shop Card
  1. FTTP (5411)
  2. BT (3492)
  3. Politics (2500)
  4. Openreach (2279)
  5. Business (2227)
  6. Building Digital UK (2218)
  7. FTTC (2039)
  8. Mobile Broadband (1945)
  9. Statistics (1767)
  10. 4G (1642)
  11. Virgin Media (1596)
  12. Ofcom Regulation (1440)
  13. Wireless Internet (1380)
  14. Fibre Optic (1380)
  15. FTTH (1379)
  16. 5G (1219)
  17. Vodafone (1128)
  18. EE (1113)
  19. TalkTalk (927)
  20. O2 (919)
