topgazza
0
The nearest point to the internal wall does not have power. However about 6 feet away there is a double power socket where all my current BT Master socket and router sits. In between there is a door.
Will the Openreach engineer be prepared to run the fibre between the gripperod and skirting under the carpet. It's not in a stepped on area and the door sill has a strip of wood separating the lounge from the hallway which protects the fibre from being directly stepped on. Currently my Master socket has been extended along this very route by BT
Or will they run the fibre around the door frame bearing in mind the corners are not rounded of course
To the right where the existing BT master socket is, now extended to the left of the door, is the most likely entry point as to the right of that is the external wall. I could cut a channel in the concrete floor and bury a 7mm flexible conduit with a draw string for the fibre but that would be messy as you can appreciate
