ajama13
Apologies in advance for this lengthy post. Need your help in understanding Openreach's response to a query regarding fibre availability for my address. The entire road apart from a couple of properties now have access to FTTP via existing & newly installed poles. My next door neighbour is able to place an FTTP order but I cannot. I have provided a visual demonstration of the layout and the placement of poles.
Believing that there is a mistake with Openreach and its database, considering the Fibre distribution point is literally across the road, I have queried this via the fibre availability customer form.
I have paraphrased what they have said, referring to the diagram above:
"I've looked into this and the neighbouring building you have mentioned (The buildings highlighted green in the diagram) is served overhead from a different distribution point than the row of houses your property is part of (these are served underground via a different piece of equipment)- unfortunately there is not sufficient capacity on the overhead equipment for us to move you over to it."
This doesn't make sense as I am on the same row at my neighbours. I am less than 10 meters away and the pole seems to have capacity for another FTTP Distribution point. I've seen poles with 2 FTTP Distribution points secured with a 'V' shaped backplate. It seems that they have made a conscious decision to skip my address and the reason provided stinks.
Can someone please help on what I can do next, as I am sick and tired of Virgin Media and its aging HFC infrastructure. I am out of contract in 9 months and would like to leave to an FTTP provider. There are no other FTTP providers in my area.
