Optimal OFP Settings
Anyone got any tips or hints to achieve better performance / lower pings, using Operation Flashpoint Online with ISDN ?
All suggestions would be most welcome.
MTIA
Pwablo
Tough 1 this Pwablo, your dealing with some pretty up n down netcode,im using win2k asuscom isnd card and freeserve as isp, i used to get a lot of drops in game[only ofp not cs ut or roguespear]. I set the protocol to old type and enabled hardware compression this seems to have helped the drops,you can also add some lines to yuor ofp.cfg file if you like MaxBandWidth="64"; and MinBandWidth="64": and just for good measure VoiceOverNet="0": Look out for a player called MrLoGiK on the fart squad servers, get the ips from <a href="http://www.fartsquad.co.uk" target="_blank">www.fartsquad.co.uk</a> server pswd is melons.Hope this helps i think it helped my drops a great deal as for BIS'S netcode its just real bad i think,thrives on dsl/cable.
Thx for that Dude, I have however already set Max and Min Bandwidth settings in ofp.cfg, but didnt know the other string, posting here was a bit of a long shot, i thought that someone here might know a ISDN tweek or two that would help. I will add the voice over IP setting to see if that helps. I agree when ya say that you think the netcode is pants, i agree, even in its latest guise v 1.75. I'll drop in by the fart squad server and see if i can see ya, and let ya shoot me a couple of times for yer help.
:D
Pwablo
