Phone after FTTP
philipel
Apologies if this is a dumb question but here goes .
I am soon to get FTTP and will receive a new phone number in the process(no problem for me)
I want to get a router with DECT capability (again researched that) but I am unclear if the new number comes down the fibre line and so can just use router as base station or will it continue using copper line I already have so connection would be:-
Incoming phone line to router then router as base station or simply incoming FTTP to router as base station?
thanks
Phil
Many thanks for replying. I understand that I could have retained my number but after an epic battle concerning wrong address/corrupt database etc. a new one was the easiest and I don't mind .
My current older DECT phone has its own base station and I want to eliminate that by using a new DECT enabled router.
Was simply wondering how the new number "gets to" the router via FTTP line or not
Might help to know which package and ISP you ordered from?
Assuming it's Openreach then you could conceivably have an FTTP + VoIP (FVA), FTTP Only or FTTP + Copper Line Phone (transition product) plan. So it's a bit tricky to answer.
If it's the FTTP + Copper line then your existing setup will be no different, if it's VoIP or just FTTP then you might want to get a router with a built-in ATA adapter (basically gives you a phone port on the back) so you can connect your old DECT station but use VoIP for the calls.
Funnily enough I just wrote a detail article on some of this:
