boogie
I've just switched from BT to TalkTalk for my FTTC broadband because BT couldn't rectify a slow upload speed that first started around mid-November last year despite 3 or 4 openreach engineer visits.
The final check carried out by BT was a 24-hour test with no devices connected. My line speed is showing as 7.5mbps at the router but the test showed a 2.5mbps result. BT told me the problem was as a result of me having 30 devices connected and this was affecting the bandwidth available to each device. There are two people in my household and these devices are two laptops, two mobile phones, two tablets, a kindle, several amazon echo devices, a main sky q box with 2 sky q receivers and several smart plugs. Only up to 2 of any of the laptops, mobiles and tablets would be used at any one time.
Regular (several times a day) speed test results show an upload speed of 0.11mbps to 0.76mbps and it's impossible to send an email with any attachment over 2mb in size. This is the same even with all devices disconnected and regardless of a wired or wireless connection. I've also noticed the speed dips even further from around lunchtime.
Since we've switched to TalkTalk there is no change (except for very occassionally I've managed to get an upload speed test result of 5.4mbps, but a test run straight after returns the normal slow upload), although I do appreciate we're only 5 days into the settling in period for the line.
Before I start to discuss the performance issue with TalkTalk I just want to see if there are any suggestions for me to try that might sort this issue without relying on my ISP or openreach?
Thanks,
Steve
Thanks,
Steve
