premium numbers
gaz
0
can any one tell me what these numbers are
because no body seems to know!
084484 81113
084471 10011
084478 80011:shrug:
Not sure what you mean by "what these numbers are", so I don't know if this helps or not, but...
From one of my old favourites, the Magenta Systems code lookup, in each case shown as "Operator: Affiniti"...
084484 81113 - Tariff Band: Multimedia 5p (g6) (inc VAT)
084471 10011 - Tariff Band: Multimedia 3.95/1.49/1p (g19) (inc VAT)
084478 80011 - Tariff Band: Multimedia 4.95/2.49/2p (g20) (inc VAT)
... and Affiniti appear to be part of "KCOM" - Kingston Communications.
Affiniti is part of the KCOM Group and was created in April 2005 from the coming together of Kingston Communications Business Services, Omnetica, the convergence business and Technica, for its storage expertise.
The fit between the organisations created something special and brought together a unique combination of network and storage expertise, telecoms knowledge and business experience.
[Blah, blah, spin, spin, bull, bull, etc., etc.]
http://www.affiniti.com/about-us/our-story/the-story-so-far.html
Does that ring any bells with you?
I'll get my coat... ;)
thanks for your reply
the numbers appear repeatedly on my business phone bill,
could it be my old dial up still being used?
That would be one possibility, though they don't look like typical dial-up prices to me.
There's certainly a modem of some sort, not a human being or an answering service, at the end of the line in each case - but, as it's a business bill, I'd suspect that it might be somebody's fax number.
084471 10011:- this number has a call duration of 40 mins in one session
iam starting to think it is my old dial up; i will investigate and let you know
the out come thanks for all your help
gaz
I'd also check to make sure that your system hasn't got any rogue diallers installed, although I doubt it because rogue diallers usually contact hidden premium rate numbers and not local call rate codes.
