Quick question for Mark
I tried to send you an email using the address that comes up when I select "Editor": m.jack%40ispreview.co.uk but the message came back as undeliverable. I live in the US; I don't know if this is the problem.
If you would send me a message to gamecock60@earthlink.net I should be able to turn around & send my message to you.
err the address is wrong did you click the link on the contact page? if so your client mis-handled the address, seems it didnt put the @ in properly instead left some of the code to circumvent bots from trawling and spamming the address.
Those addresses are encrypted using anti-spam bot code, though when you click them it should come up as the correct @ address in your e-mail client. I’m not sure what e-mail system or character encoding you use and it’s possible that the %40 might not get converted, especially if you use a browser imbedded e-mail client. In that case, just change %40 for an @ sign.
