Quickline FTTP - installation & own router settings/info
Maltbyite
Hi All,
I've been a long-time reader of this forum and found some great information on here, so I thought it was about time I helped the community by providing a bit of info on my recent Quickline FTTP install that was done this week as well as providing some information that I found hard/couldn't to find.
Installation
I've had the new FTTP connection in now (200Mbps symmetric) for a couple of days and other than some very early teething issues (which I'll touch on in sec) it was no hassle at all. At the time of ordering (early Oct 2025) they had two offers, 50% off for 2 years or "free until you're free" (i.e. free until your current contract finishes then fuill price for the remainder of the 2 year contract) - I went for the latter given I had 16 months left on my FTTC connection.
It was two weeks from order to installation, about a week before installation day, a team came round and ran the fibre from the pole (over the road) to a point on the brickwork outside. They asked where I was likely to want the ONT and run it to just outside. On the installation day, another team came round to to fit the ONT and junction box outside - again asking where I'd want them. The installation job was very neat (even got approval from the SO!) and they set up everything including the router so it was just connect and use. The router they provided was a Zyxel EX5601-T0, seems like a decent unit from the couple of hours I spent playing with it
The only issue I had was immediately after the install, I was only getting ~500kbps download but full (200Mbps) upload. After a power cycle of the Adtran branded ONT, it reconnected no problem at full speed (about 10% faster actually!) and has been stable since.
Own Router - settings and issue
After a day of using the Zyxel router, I decided it was time to move my network from the FTTC connection (which I still have given the "free until free" offer) to the Quickline connection, so replacing the router with my Netgear RAX120. I'm lucky enough to have Cat6a wired around the house so it was a matter of moving a few cables and updating the settings in my Netgear whilst keeping everything live.
After reading this post (https://www.ispreview.co.uk/talk/threads/finally-fibre-is-coming.38702/post-328231) I was hoping it would be as easy as updating the PPPoE settings and off it'd go - unfortunately it required more tinkering than that! The PPPoE username and password can be found by logging in to the admin page of the Zyxel router and copying them from there.
After an hour and a restart of the router and ONT, it was clear that more settings needed to be changed. I've taken a screenshot of the settings from the the Zyxel and attached here for reference. In the end, I found I had to apply the following settings for the Netgear router to connect;
  1. Update the PPPoE Username & Password
  2. MTU - I didn't need to change this as mine was already set to 1492.
  3. Enable IPv6 using the same settings as IPv4 (i.e. item 1)
  4. Enable VLAN (my Netgear's Vlan page doesn't seem to break out between 802.1p and 802.1q but just enabling it seemed to work)
I've asked Quickline if they can provide details of the settings that need to be changed (annoyingly they don't publish them online) to see how much/little of the above is needed. I'll update when I hear back from them.
This seems to work really. The only minor issue is that I seem to to have lost some upload speed (which varies between 70 and 170 Mbps on the Netgear whilst it was constantly >200 on the Zyxel) - download speeds are unaffected. I'll have another tinker with the settings when I hear back from Quickline or if anyone on theis forum has any ideas.
Hopefully this'll be useful for someone looking at Quickline FTTP; happy to help if there's any questions.
Cheers
Maltbyite
Hi All,
Following on from above, I've heard back from Quickline support and below is what they've suggested the settings should be.
Please configure your router using the following Information:
General:
Mode
= Routing
Encapsulation = PPPoE
IPv4/IPv6 Dual stack
VLAN ID is required to be enabled with the following values.
802.11p: 0 & 802.11q: 911
Please set the MTU to: 1492
Your PPPoE credentials are as follows:
  • PPP Username: [provided by support, same as what was on the Zyxel router]
  • PPP Password: [provided by support, same as what was on the Zyxel router]
Routing features:
NAT
= Enabled
Apply as default gateway = Enabled
IGMP Proxy = Disabled
Fullcone NAT = Disabled
Please ensure that for both IPv4 and IPv6, that Obtain IP address automatically and Obtain DNS info automatically are selected.
IPv6 Routing features:
MLD Proxy
= Enabled
Not all the settings as mentioned above may be present. If the router does not have the option to enable and configure a V-Lan on the WAN interface, you may not be able to use that router.
Please also note that we will not be able to support this device, as we do not have access to it. For ease that we can confirm your connection status in the future, please enable/allow ICMP traffic on the router. For any issues related to the router, please refer to the manufacturer's support resources.
