Reasons not to go with O2 if you travel abroad
Umm do not setup plan cause unless you actually said want unlimited liability, they can't give bills like that stolen or not. Aka it would of cut off once bill reach £65. Call customer relations and if they won't cancel bill, ask deadlock letter and go to regulator / media.
Wow, stuff of nightmares, but I am sure it will get fixed.
This is the kind of reasons I always set an expense limits on any mobile contract (usually I set it to 0).
There's a £45 limit on data only, not sure for calls, seems like the main expense in this case were indeed the calls.
And you can decide to opt out anyway, it's not an actual block.
True might of opted out (if look at those roaming passes it opt u out) but I would argue that volume their system should pick it up much much earlier
This might be a daft question, but did you report it stolen to o2 immediately, as they will normally block and cover calls made after you reported it stolen and even before you reported it as long as its within 24hours,,,
