Router keeps dropping connection
akbray
I have a Wireless Box II, running firmware version 7.4.20.4.
Every so often - as little as 30 minutes sometimes - my router drops its internet connection (internet light goes red), then quickly reconnects again without a problem, at least for another 30 minutes or so.
During this time there are no obvious reasons for the drop - sometimes I'm not even using the computer or the phone. This is a problem because I use my connection for online gaming, which is nigh on impossible with an unreliable connection.
I have reset the router, checked the cables etc but it hasn't made any difference. I have also changed router DNS settings to openDNS, but its not helping.
Anyone got any ideas?
Mark.J
Administrator
Staff member
ISPreview Team
You know the drill akbray, post your router stats ;) .
Sounds to me like your Noise Margin might be occasionally dipping too low and cutting out the line.
akbray
I must have been having a blonde moment to forget the stats! :)
It has been dropping for a while, but it was only last night that I got round to actually monitoring it. The connection was dropped regularly after 30 mins (with the usual quick reconnect). I did a reset of the router (after spending 20 mins looking for a damn paper clip!) and checked the stats again this morning. It had dropped again after the reset, but had then maintained connection for 5 hours overnight.
I will post router stats when I get home tonight (assuming snow doesn't stop me getting home at a reasonable hour - it took me 8 hours to get home during the heavy snowfall at the end of December, and the weather forecast is similar for today. and tomorrow).
akbray
Uptime: 0 days, 1:56:51
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,170 / 8,187
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 0.00
Output Power (Up/Down) [dBm]: 12.0 / 18.5
Line Attenuation (Up/Down) [dB]: 10.5 / 21.0
SN Margin (Up/Down) [dB]: 9.0 / 16.0
Vendor ID (Local/Remote): TMMB / BDCM
Loss of Framing (Local/Remote): 36 / 0
Loss of Signal (Local/Remote): 4 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 11 / 0
FEC Errors (Up/Down): 45 / 4,412
CRC Errors (Up/Down): 45 / 1
HEC Errors (Up/Down): 4,029,548 / 0
It actually held its connection from about 12.30 last night and the dropped it at just after 8pm, but has been ok since.
Mel
That seems a heck of a lot of HEC errors for a 1 hours & 56 minute uptime. Are there crackling noises on your phone line?
Edit.: oh, I just noticed they are in the up direction, that seems a bit odd.
HaydenHarnet
Guest
try changing the channel , this has solved the problem for many people
KDS
I had the same trouble with O2 wireless box II, It was unusable I think it just slowly dies after a year or two. I'm now using Netgear DGN3300 v2 works with out any issues, I haven't had single dropped connection.
I had Belkin v1 router it had a better wireless coverage but died in few days. Netgear DGN3300 v2 so far working well for me
akbray
I need a good basic modem router - is the Netgear DG834G any good? I don't need wireless N etc, I just need something reliable, and I can get this one for about £30.
Also, is there such a thing as a modem/router with the ability to plug in a USB HDD and use it as network storage?
Any comments?
Mark.J
Administrator
Staff member
ISPreview Team
Off-hand, I know the Netgear DGN2200 has shared USB storage support and quite a few others but I am not hugely familiar with them. Nice feature to have though. The DG834G is good for raw line speed but I have kind of fallen out of love with NetGear because their Firewall's are annoying.
LeeH
ISP Rep
It is more likely that there is a issue on the voice line with the problem being on the upstream.
Its the usual suspects really try a different filter int he test socket and test the line via 17070 quiet line test with a non digital phone as some do have noise canceling built in.
From the sats though you will have a good line once this is sorted out it should give around 12-13meg i would of thought if not more.
akbray
Those stats were from January - it has been behaving much better for a while (I did a factory reset which seemed to help) although it still drops fairly regularly (at least once a day -sometimes more).
Getting disconnected from Xbox Live in the middle of a game is starting to get very irritating!
Current stats are:
Uptime: 0 days, 10:51:45
Bandwidth (Up/Down) [kbps/kbps]: 1,313 / 8,187
Output Power (Up/Down) [dBm]: 12.0 / 18.0
SN Margin (Up/Down) [dB]: 7.5 / 14.0
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Error Seconds (Local/Remote): 0 / 0
FEC Errors (Up/Down): 415 / 56,346
CRC Errors (Up/Down): 415 / 7
HEC Errors (Up/Down): 12,168,377 / 2
akbray
Just done it again:
Uptime: 0 days, 0:04:48
Bandwidth (Up/Down) [kbps/kbps]: 1,325 / 8,187
SN Margin (Up/Down) [dB]: 6.5 / 13.5
FEC Errors (Up/Down): 35 / 233
CRC Errors (Up/Down): 35 / 0
HEC Errors (Up/Down): 12,169,154 / 0
LeeH
ISP Rep
Its deffo the upstream thats causing the drops the downstream sync rate hasnt changed but the up has and with all them HEC errors theres something needs to be checked out
  • Vodafone £21.95 (*24.95)
  • NOW £22.00 (*32.00)
  • TalkTalk £22.00 (*29.95)
    Gift: 12 Months of Norton 360
    Gift: Double Speed Boost
  • Vodafone £25.00 (*28.00)
  • Gigaclear £29.00 (*49.00)
    Speed: 300Mbps, Unlimited
  • Hyperoptic £29.00 (*35.00)
  1. FTTP (3301)
  2. BT (2959)
  3. Building Digital UK (1867)
  4. FTTC (1861)
  5. Politics (1851)
  6. Openreach (1774)
  7. Business (1616)
  8. Mobile Broadband (1399)
  9. Statistics (1366)
  10. FTTH (1361)
  11. 4G (1210)
  12. Fibre Optic (1138)
  13. Wireless Internet (1124)
  14. Virgin Media (1112)
  15. Ofcom Regulation (1110)
  16. Vodafone (798)
  17. EE (798)
  18. TalkTalk (740)
  19. Sky Broadband (720)
  20. 5G (692)
