meritez
eSIMs
Like a traditional SIM card, an eSIM stores the data your device needs to use the network. ‘eSIM’ simply means an embedded SIM, but unlike a physical SIM card, an eSIM is already built into your device. It also allows you to have multiple lines on a device, that you can switch between. The RWG...
www.rwgmobile.wales
The RWG Mobile eSIMs run on the Three network and allow VoLTE and WiFi calling.
Multi Network SIMs
20% OFF with discount code "MULTI20". Apply at checkout. Multi Network Data only SIM cards get better signal coverage and bandwidth than single network SIM cards because they are able to connect to multiple mobile networks rather than just one. In the UK there are four mobile networks Vodafone...
www.rwgmobile.wales
