The Wee Bear
I wish O2 were as efficient, I'm still waiting on my eSIM arriving by post.
Might be the Royal Mail though, so can't blame O2 100%.
What does the network name appear as at the top of the screen I'm assuming Gamma or is it RWG?Definitely using three because it's missing from the list.![]()
It appears as Gamma Stewart.What does the network name appear as at the top of the screen I'm assuming Gamma or is it RWG?
I'm assuming IP address would be Three?
IP address would be Gamma TelecomWhat does the network name appear as at the top of the screen I'm assuming Gamma or is it RWG?
Are you not an O2 360 customer?I wish O2 were as efficient, I'm still waiting on my eSIM arriving by post.
Might be the Royal Mail though, so can't blame O2 100%.![]()
I am chrisyyw, but it didn't work online for me, don't know what happened.Are you not an O2 360 customer?
My eSIM QR was generated in minutes.
I’ve ordered the multi-network SIM on the 1GB tariff to see how it works.
Will report back when it arrives in the post.
I'd hold on for the moment, if RWG is moving their customers then they'll be announcing it to each customer.So do I need to buy a new bundle to shift my RWG yearly sim to an eSIM?
Incredibly unfortunate to see that it's 2G/3G on O2 and Vodafone, still helpful for an EE/Three backup thoughHad a bit of a chance to play around with it now and it's not great. It's a SIM from tele2.se that roams across all 4 networks. There's no capability to make phone calls or send SMS and the ping is trash, assuming it's because traffic is being routed via Sweden.
In order to connect to O2 or Vodafone you have to change the APN to 'key' or you get no data.
- Three - Looks like it's their preferred roaming partner in the UK
- EE - Connects and I have 4G access (not bad speeds either)
- O2 - 3G only
- Vodafone - 2G only (assuming it was 2G/3G only but 3G is switched off)
I'll double check in the morning, it's a physical SIM rather than an eSIM.Last year I tested EasySim and initially O2 would only use 3G. Next day 4G was available.
Maybe this eSIM is 2G/3G only for VF and O2, but check again tomorrow, it might be different.
Update: O2 4G is now working and I have 5G access on VodafoneLast year I tested EasySim and initially O2 would only use 3G. Next day 4G was available.
That's better did you have to change anything or did it just start working?Update: O2 4G is now working and I have 5G access on Vodafone![]()
No changes, it just started working of it’s own accord.
How do you check your remaining data?
