Samsung Logs 1.75Gbps Download Speed at 10km (mmWave 5G)
The Wee Bear
Mmwave's major problem was range ..right?
If the article is correct than its a telecom revolution .!
It does sound like that Roguee.
I was reading about the new 5G (mm wave) towers they’re installing in NYC. All 2000 of them!!
Sounds a bit fanciful. In real-world conditions with thousands of users I suspect the reality will be different!
MMwave’s problem is objects getting in the way. If you can get a direct line of sight and a decent amount of power between an end to end radio system then it will travel.
● Wi-Fi, millimeter wave 5G, sub-6 GHz 5G and 4G LTE are all crucial building blocks in providing different layers of coverage
● Wi-Fi and 5G are complementary, not substitutes
A sensible approach in my view
