Samsung S24 Ultra
mikeliuk
For the first time in years, I've been forced to get a relatively good mobile as my Cat S26 Pro started to expand as probably the first stage in the explosion of the battery.
I looked up various recommendations on YouTube and my first priority was to configure settings to prolong the life of the Samsung S24 Ultra battery so thought I'd document on here for discussion of the Samsung S24 Ultra (not necessarily to make power-saving the topic).
Settings -> Display -> Screen resolution -> HD+ 1560 x 720 (worst compared to FHD+ 2340 x 1080 default, and recommended QHD+ 3120 x 1440), Dark Mode always on (power-saving due to OLED), Motion smoothness (Standard, refresh capped at 60 Hz instead of 120 Hz)
Settings -> Battery -> Battery protection (maximum, charging capped at 80% battery), Power saving on most of the time (CPU capped at 70%, 5G off, etc.), Charging settings (Fast charging off, and Fast wireless charging off)
Settings -> Lock screen and AOD -> Always On Display (off)
Dark image, Hubble Ultra Deep Field, for lock screen and background.
Adding some additional info to track over time:
One UI version: 6.1
Android version: 14
Current version: S928BXXS3AXGF / S928BOXM3AXGF / S928BXXS3AXGF
Security patch level: 1 August 2024
Product name: Galaxy S24 Ultra
Model name: SM-S928B/DS
Kernel version: 6.1.25-android14-11-28243294-abS928BXXS3AXGF #1 Thu Jul 25 12:47:17 UTC 2024
An update has been reported in https://www.ispreview.co.uk/talk/threads/samsung-galaxy-events-news-updates.39291/post-384949
One UI version: 6.1
Android version: 14
Google Play system update: 1 July 2024
Baseband version: S928BXXU3AXH7
Kernel version: 6.14.57-android14-11-29543898-abS928BXU3AXH7 #Fri Aug 16 09:26:12 UTC 2024
Build number: UP1A.231005.007.S928BXXU3AXH7
Service provider software version: SAOMC_SM-S928B_OXM_EUX_14_0138
EUX/-/EUX/EUX
Android security patch level: 1 August 2024
Build Number : S928BXXS4AXJB
Android version : U(Android 14)
Release Date : 2024-11-04
Security patch level : 2024-11-01
• Auto Blocker
After the update, when “Auto Blocker” is on with “Maximum restrictions”, USB devices will not be allowed to connect to this device except charging.
• Security
The device is protected with improved security.
