Samsung SCR01 Mobile WiFi
JoeyC
This is my first post so unsure what category my thread should be under.
I hope someone can shed some light. I purchased a Samsung SCR01 mobile WiFi device from Japan, from reviews etc it appears it basically is a modified A32.
According to Three’s online coverage checker a few of my masts are 5G enabled however this device only supports N78 5G band. I have modified the necessary settings to allow 5G connections but can’t pick up 5G.
Is the N78 5G band not supported in the UK?
Three do use N78 in the UK so i have no idea why it would no pick it up. are you setting it up as SA or NSA? as three use NSA currently.
I’m not entirely sure the only setting I have is to enable NR SA in service mode which I have enabled. I assume that means SA as opposed to NSA 🤷‍♂️
