Sky Connect speed issue
  • Thread starter Thread starter Unregistered
  • Start date Start date
It's not Sky limiting you, it's BT's line management software. For that low a profile, you must have had one or more low-speed sync events. It suggests that you need to take a good look at your internal wiring to remove any noise pickup, which is the most likely cause of the low-sync events. Disconnect the ring wire at every socket, not just the master, and ensure that you are using pairs, eg blue/white with white/blue, throughout. Disconnect any extensions you don't need and double-check that everything connected to the line is filtered (except the router, or course).
If your sync speed increases, and is held for three days, your profile should rise again.
Thanks for all your help out there.
As said, I've got the BT Option 3 finally installed. Put the hub directly into the master socket using an ADSL faceplate. I've purchased a D-Link USB wireless and that allows me to connect wirelessly without any of the problems I had before with problematic intenal wires. I've got a 2.2mbps connection at the moment but I think it shoud rise to 3.5mbps once it's all settled down.
Only problem I have now is that none of my landline sockets work except the BT Test socket one. The Hub is connected to the ADSL faceplate but the RJ11 telephone plug socket next to the ADSL plug on the same socket doesn't work. Neither do any of the other sockets in the house. I'm hoping its a faulty faceplate so I'm going to order a new one.
