Slow upload speed with a 5G Router in 5Ghz band
eemix
Been asking the same in other threads
I live in Greece and I just bought a ZTE MC801a 5G sim router to use it as hot spot.
I bought also a new ASUS PCE-AX3000 WiFi 6 adapter for my 4-5 years old I5, 32GB ram Desktop
The router placed indoors of course 4 meters away (no walls between) from my desktop
Testing speeds with the 5GHZ band, i found out that my Desktop reaches 13 Mbps average uploading speeds while the same time from the same spot my smartphones (Huawei P40 pro - Vivo X70 pro plus), in flight mode, connected via Wifi of course to the router reached 50Mbps average uploading speeds, and sometimes topped at 70+ Mbps. Same lame uploading speed i reached even with my almost new I5 laptop. Downloading speeds are almost equal to any device in any test.
I tried too many combinations, played with router's 5G settings, but every time upload speed cannot go over 15 Mbps.
I turned off firewall but nothing.
Is it protocols, DNS settings, what?
Any given ideas are more than welcome....
Thanks on advance.....
Those are two good phones you have there but still a bit weird for the difference to be that significant. The 2.4ghz test might be worth trying for comparison.
and..... these on 5Ghz on 4G+ and 5G
A little....better results on 4g+ in uploading
and these what the smartphone measures
Better speed on 5g this time
At least your pings are fairly impressive! Those speeds are plenty good enough for most use-case scenarios.
but what if you know you can get a lot more and something holds it back. That's what I'm trying to find. And you know, i send to clients large files of works (300, 500 mb or even a TB) so uploading is something it bothers me a lot
then I would maybe use the smartphone as a hot spot...to upload
I fully understand, I'm sure most of us would be the same too! How would using the phone as a hotspot improve the upload speed from pc/laptop? Maybe try that wifi6 internal card for your laptop that Troy suggested earlier(if it fits yours), cheaper than the USB dongle you suggested.
Till last week i was using my smartphones as hot spot. But during heavy downloading or uploading they were too..... hot (spot). The heat shorten the life of battery or the smartphone's itself. And the speeds were lower than ZTE's. Bottom line, i can live (I think) with 15Mbps but on the other hand it is a mystery that it must be solved....
If the battery were to degrade it's not to hard to fit a new one, so I wouldn't let that put you off.
In my experience, the only PC WiFi 6 cards that work properly are the one with an Intel chipset (ie AX200/210).
That said, look for updated drivers for your card from chipset manufacturer (not from Asus).
If yours is Intel-based, use this driver:
Been searching in the internet for solutions, I saw that somewhere written, and i installed this driver from the 2nd day. Unfortunately nothing happened, that's why I ended up here asking for help.... Thank you for replying anyway. From what I see after numerous of tests with different settings, the upload through windows reaches max 25% of the real upload speed capabilities from ZTE router. (based on my area 5G coverage)
The question is for ZTE router holders, does anyone use PCE card in his Desktop, what card is this and what uploading speed did he measure in comparison to his smartphone.
Is it possible the Mobile company (eg. in my case: Greece Cosmote) recognizes from the MAC address that it has to do with desktop (anyway not a smartphone) and sets limits to upload speed?
The UK almost always uses 5G NSA which relies on a 4g component for uploads. My 5G signal is borderline so I have to sacrifice NSA's 4G component a little in order to maximise it because my 4G signal is from a different mast to 5G. As a result my upload speed isn't optimum because that relies on the 4G signal. If Greece is the same as most of the UK then you will also be using NSA 5G and using 4G for your uploads. While uploading large files your download speed isn't important, therefore I would site your router location for the best 4G signal and switch your router to 4G only when uploading.
I don't do much uploading so it doesn't bother me much but when testing if I did this my upload speed almost doubled.
The upload speed is identical both in 4G and 5G network from PC and Laptop. An it is always approximately the 25% of the uploading speed i measure in smartphones. It is insane and if my area reaches 70+ Mbps uploading speeds, I cannot understand why it may exist any limitation for non smartphone machines.
What I am suggesting is to locate the optimum spot for 4G because that is what controls your upload speed. Location and orientation can be quite sensitive for many mobile routers. Even turning it through 180 degrees can have an effect on signal levels. Another possibility is that your router isn't aggregating the best 4G bands for speeds. If you can find out what bands your phone is using and lock the router to the same ones.
I positioned the router to many indoor spots in my house and i ended to the very best, also considering that i want direct contact with my main PC , without interruption from walls etc. The place of the router is not the problem, any limitations to MAC addresses of desktops and laptops may be. I attached speeds from Desktop and smartphone, which I've just made.
Looking at those two results, they seem to be connecting to different servers.
The result on your phone was connected to EASY by Europlanet Athens while the desktop was GRNET Athens.
Try manually changing the server on the desktop to EASY by Europlanet to see if it makes any difference.
