Do cat 18 routers exist, or routers that can achieve that speed?The b535 is cat7, redmi cat18.
Like comparing a bicycle to a motorbike
Yes, Huawei CPE Pro, CPE Pro 2, ZTE mc801a, 7010, zyxel nr5103, nr5101.Do cat 18 routers exist, or routers that can achieve that speed?
what about the vn007?Yes, Huawei CPE Pro, CPE Pro 2, ZTE mc801a, 7010, zyxel nr5103, nr5101.
There's others as well
Vn007 is cat12, perfectly decent but not cat18 as you asked about.what about the vn007?
Would I notice a massive difference between cat 12 and cat 18? i was going to buy the zte mc801a for £250 but got scared by all the firmware problems... my b535 runs solid on vodafone(lebara) albeit i only get 40mbps daytime at night it gets close to 100mbpsVn007 is cat12, perfectly decent but not cat18 as you asked about.
You would notice a difference between cat7 and cat12, plus you would be ready for 5g when it arrives.Would I notice a massive difference between cat 12 and cat 18? i was going to buy the zte mc801a for £250 but got scared by all the firmware problems... my b535 runs solid on vodafone(lebara) albeit i only get 40mbps daytime at night it gets close to 100mbps
