Smart TRV (thermo radiator valve) recommendations?
Lucian
I'm replacing some rads and I'm tempted to look for a smart thermostatic valve.
My needs are that I should be able to set time intervals of various temperatures or even set the valve off (say when kids are in school).
I'm looking for something strictly non-cloud, ideally not networked at all, but programmable somehow. If it came with a wall digital thermostat where I could configure it from that'd be pukka!
Thanks!
Hi Lucian,
I've been using Honeywell EvoHome since 2018 and it has been rock solid, the TRV heads happily take rechargeable AA batteries and tend to last a good 9 months. However our CH is rarely used because I'm a tight Northerner and choose wood as our primary heat source.
It would certainly fulfil all of your criteria and whilst I've got mine linked to the Internet, I believe it will run quite happily without.
The controller has a limited internal rechargeable battery and can go on a mains powered "dock" or a wall mounted with a permanent mains feed.
Shelly TRV
Can be cloudy if you want, can operate local wi-fi via a smart phone application and very easy to integrate into a Home Assistant setup.
2 plus years battery life.
Out of stock here ...
Switched from the Honeywell (Now called Resideo) junk a couple of years ago and don't regret it, have a lot of Shelly stuff and it's well supported with software updates and very easy to integrate into a locally managed smart home system like HA.
Shelly TRV
It doesn't require a hub or gateway, does it?
