Speed Issue with Huawei AI Cube B900 on Three
McMonty
I have noticed that the speed keeps dropping from between 25 - 30 to below 3 Mbps over the course of any given day. I had the cube for around 1 month and all was fine in the beginning, but during the last couple of weeks the speed has dropped. I restart the cube, the speed goes back up and then a few hours later has gone down to below 3 Mbps . The speed will always go back up again after the restart.
Has anyone come across this or know a fix?
I thinks its a common issue, get you past a certain period then start throttling you. Have read many people have same issues.
maybe a VPN will cure this problem?
Doesn't vpn mean slower speeds?
Marginally, but with Three it sometimes gives you faster speeds because it evades the content throttling that happens.
That being said - if your speeds are generally always pretty poor then it's likely due to Three having too many customers in your area and are not keeping up with the demand well.
You'll find the AI Cube will magically speed up if you just switch networks. Not that easy if you're in a contract, mind. But I just got out of mine with Three and switched it over to Vodafone.
Well the voxi unlimited data glitch ended so returned to Smarty. Having said that, the speeds are a little better on my B535 than it was on the MR200.
Verified, I was having the same problem, I have got the card from the router and inserted it in the phone, I put the phone in the place where was the router doing thetering. Result, excellent performance, so the problem is the router huawei from Three.
