Stageshoot
Ok, this is an odd one
Setup.
5G Router CPE Pro
3 Sim
Up till last week we have been getting a good signal from a distant 5G Pole of Wonder, difficult to get a signal but its worked fine, everything on the home network has always worked no issue.
Couple of days ago new Pole 500m away goes live, speeds great no need to hunt for a place for the router to get a signal.
All Great EXCEPT. Since moving to the new pole our Phillips Hue Home Hub with controls access to the lighting in the house can no longer see the internet using the standard settings on the hub. Its just become invisible to the outside world. So cant turn any lights in the house on or off using Alexa etc.
Thats using the standard 3Internet APN.
Switch the router to three.co.uk (CGNAT) and the Phillips Router springs to life and works connects to the internet no problem
Problem is do that and my downloads from Newservers fails as it flags as account sharing due to the CGNAT
Cannot understand why the old 5G and previous 4G towers have worked great. But on this new tower just the one device (Phillips Hue Hub) is 100% invisible unless using the CGNAT phone apn.
Have tried resetting everything manual and DCHP on the hub have tried moving it to the DMZ on the router and setting up port forwarding but nothing.
Any of you have any ideas I can try I am stuck and its annoying having to shift the router back to CGNAT on the three.co.uk apn to switch on the lights!!
Setup.
5G Router CPE Pro
3 Sim
