Constant re-detection of the speedtouch modem on more than 4 machines using XP and 2000... plug in the sagem.. works fine.
drsox said:they insist on confrence calls with alcatel.
Alcatel blame the chipset drivers (which are fine)..
akbray said:I have used a Speedtouch 330 for the last 2 years as well (on both 98SE and 2000, now plugged into a router) and have suffered none of the problems you have. Mine was originally supplied by Freeserve as well.
Other than making sure the drivers are up to date, I have not had any issues with them at all.
Andy
drsox said:Anyhow. After a 2 hour wrestle with freeserve support they then did a confrence call with alcatel.. who within 2 minutes said "yep.. we have this fault with some modems.. here is a returns number"..
I really think freeserve support monkeys sit with a sign on the phone saying "dont help the customer!!"
