dobbyhdm
I hope you can help!
TLDR question: What is the 'best value' LTE & 5G Router? any and all suggestions/gotchas welcomed!
Over the last 4 weeks I've been trawling the web (mostly this forum) to find the best 'bang-for-buck' 5g/LTE router option.
My problem is, there is so much information spanning the last 2 years or so, some of which is contradicting and left me a little perplexed.
Current Situation
I have borrowed a Mikrotik SXT-6 that has provided an acceptable 45mbps, bu this tails off after around 3 hrs to 12mbps. I have been in touch with EE and hey have assured me there is no 'fair use or QoS that should affect this.
In the same place, on my S24 Ultra Im getting 110mbps (on 4G). I suspect this is down to the fact the phone s not limited to the CAT 6 CA capabilities?...
The reason i am looking for a 5g option is that it is coming to my area shortly, so i am looking to future proof where possible. The device will also likely be hooked up to my campervan and used as a permanent solution for working on the road.
Looked at so far:
Current Situation
Looked at so far:
- ZTE MC801A 5G
- Zyxel NR5103E
- Robustel R5020
- ZTE MC888
- And so many more.
