Tplink m4r deco and three 5g hub zte mc888
cavper
Hi
I have a three router/hub and am trying to connect my Tplink M4r deco to it but have not been able to.
does anyone know the settings I need for it to work or if it is even possible.
I have 3 deco units and have used a cable to connect the first one but the light just stays on red
I have tried three support and they have just told me to go to tp link support who tell me to go back to three
any help would be appreciated
many thanks
Hi
many thanks
Have you downloaded the deco app & connected the M4 main deco successfully.
Consider selection AP mOde in the app and you should be just plug and play
hi thanks for the reply. yes I have changed to ap mode and it still doesn`t work
i have made a new apn
changed pdp to ipv4 ( other options are ipv6 and ipv4v6)
profile is changed to three.co.uk
authentication is set to none
