Two FTTP lines?
johnnyUK
Hi All
I'm lucky enough to have 300/50Mbps FTTP.
Regardless of whether it's good value or "you'll never need it", I'm curious as to whether I could have a second ONT if I wanted one?
Thanks!
You can have up to four FTTP connections on one fibre - OR would install a four port ONT for a second connection not an additional ONT(this would require a separate fibre optic cable).
Thanks for the quick reply! I should have asked in a different way - can I have two 300Mbps lines? Or in the future two 1Gbps lines?
You'd of course have to ask why you'd need two FTTP lines, particularly as single line speeds will only get faster in the future (consumer lines tend to be 330Mbps but a new 550Mbps and 1Gbps tier for homes is already on the way). Likewise if the concern is phone then you can easily setup several VoIP accounts.
Yes you can. I have a multi-port ONT and on port 1, i have a 330/30 service (FTTPoD) which is for business use and on port 2 i have a 330/50 service which is for residential use. If you only have a single port ONT then this will get swapped out for a 4 port ONT if you were to order a second FTTP service.
Virgin Media £24.00
Shell Energy UK ISP Logo
Shell Energy £26.99
109Mbps
Plusnet £27.99
Zen Internet UK ISP Logo
Zen Internet £28.00 - 35.00
Gigaclear £15.00
YouFibre UK ISP Logo
YouFibre £19.99
BeFibre UK ISP Logo
BeFibre £21.00
Gift: £25 Love2Shop Card
  1. FTTP (5472)
  2. BT (3505)
  3. Politics (2524)
  4. Openreach (2291)
  5. Business (2251)
  6. Building Digital UK (2234)
  7. FTTC (2041)
  8. Mobile Broadband (1961)
  9. Statistics (1778)
  10. 4G (1654)
  11. Virgin Media (1608)
  12. Ofcom Regulation (1451)
  13. Fibre Optic (1392)
  14. Wireless Internet (1386)
  15. FTTH (1381)
