Two Questions...
Just wondered if someone could answer two questions: Firstly, because of the area I live in, we're only able to have satellite dishes on the roof - might this be a problem? The Sky dish is currently on the roof without any problems seemingly.
Secondly, with SatDrive's inclusive package (£34.99), is there an indication when you've reached your 1024MB limit at level 5? Does the software allow you to monitor your usage at a certain level so you don't suddenly get huge bills through the door? Cheers
with regard to dishes, so long as it has a clear view to the southern sky then it is fine, you can mount it where you like, so your roof will be fine.
I am not sure about sat drives software, but you could always use a program such as "DU Meter" which will monitor the speed and quantity of data, it logs it day by day giving you transfer totals in day and month columns :)
