Upgrade Router (Im with Hyperoptic 1gb)
zakir1988
I want to upgrade my routers I have Nokia Hyperhub From provider Which I have a Second router connected HUAWEI AX3 (Dual-core) which is connected to my provider router downstairs which is connected via ethernet cable.
Should I upgrade as Nokia Hyperhub lacks in specs not wifi 6 but it doesn't matter to me as most of my gadgets aren't wifi 6 compatible.
I read on some threads here devolo Magic 2 WiFi 6 get recommended alot
I know its not a router its a powerline adapter.
Current set up has no problems at all.
Should I upgrade or leave it as it is.
Im going to buy Fire tv cube 3rd generation soon.
I think you answered your own question...
Should I upgrade or leave it as is.
I would leave it alone until there is some material benefit where spending time and money to change it is justifiable. Unless of course you have a burning desire to just tinker and have money available to fund that habit.
A lot of routers have issues with 1Gb services, so as Plunet suggests unless you have a problem with functionality stay with the router supplied. Most support will insist on you putting their router back in position for tests before they accept a fault anyway.
