TTJJ
Thought I'd just share a link to something I bought and had success with recently on Aliexpress. It essentially just converts your fibre connection into standard Ethernet. Useful if you're with a restrictive ISP.
I don't like using the ISP supplied router, even when it's put in bridge mode. So, I used this instead and have had great success with it. I recently moved from a GPON network (I had a small Huawei ONT previously) to the upgraded XG-PON one so my old ONT wouldn't work - but then I found this one which supports basically all of the standards (X and GPON as well as the XG variants).
Depending on how your ISP authenticates, you can set the SN of the device, the LOID, GPON Password etc. and then just use either DHCP or PPPoE on your own router to connect.
Very useful indeed.
Very useful indeed.
