Virgin Hub 3, TPLink AV600, Mesh recommendation please
Reddodgydon
So apologies, tried to find advice on this but struggling, Virgin Hub, signal non existent at rear of property, need network for office and remote garage, currently run a Cat 6 cable outside house to office into an LAN port / booster then a cable to a TP link AV600 which goes to the garage then hardwired lan into a pc the wireless is network is rubbish from the extender AV600, I’d still like to use an extender through mains cabling to the garage ( and no I can’t run a cat 6 cable to the garage) but would like to use multiple mesh type Wi-Fi like TP Deco, but wondering if it will clash with the Wi-Fi on the AV 600 happy to start over with good recommendations, Thanks in advance !
Personally, I prefer powerline adapters and integrated WiFi access points, because it seems illogical to cure a WiFi problem with a mesh network relying on good WiFi transmission.
At the moment, I use Devolo Magic-2 powerline adapters but others are also available.
