Vodafone 5G Gigacube H112-370 - 3rd Party Replacement
Turbotim
Hi There,
I currently have a Vodafone 5G Gigacube H112-370 but unfortunately it does not have the features that I require. If i were to remove the SIM and use in a 3rd party 4G router does anyone know if this would work please?
Provided the third-party router isn't locked to a network and can harness the same spectrum bands, as well as 5G NR if you don't want to be stuck on 4G, then yes it should work. But you may need to have the right APN settings for Vodafone.
