Vodafone/O2 tower problem's in ML7
Hardie
Was wondering if anyone has had any issues similar to this in the past I use Vodafone as a main sim as they offer 2nd best coverage and speed to EE in my Small Town and Three as a 2nd sim which isn't fantastic as they only have 1 tower and speeds are dire
Unfortunately the 5 nearest phone towers have been showing as having issues all day so everything in a 3 mile radius I'm getting 0 Bar 3G and 4G so it's basically unusable and WiFi Calling won't activate for some reason
Upon checking O2 they are having the same issue I'm guessing shared towers there service check shows that one of the towers is water damaged doesn't say which
Anyone know why this would be effecting multiple phone towers leaving the entire local area with no or very little Vodafone/O2 coverage?
O2 and Vodafone have a mast sharing agreement and if there is water damage in the equipment at ground level say, this would impact both, meaning the CTIL team would need to come out and repair it. It could all be on the same loop, so once one is out; the rest go too.
You could check out 1p Mobile depending how you use your phone, 50gb for £15 with full access to the EE network including 5G and wifi calling. Mins and texts charged at 1p each as the packages don’t come with allowances.
