Nomader
Hi all,
So this is a weird problem and will try and explain as best as I can. I have the version 1 of the zyxel device.
Getting speeds of over 200-700mb download depends where I am in the house and about 100-160 upload. Mind you it didn’t used to be like this. It used to be around the 150mb for download but some how it’s increased over the past month. Anyways not complaining about that.
However I have noticed certain apps throwing up errors like I don’t have an internet connection. I maybe scrolling the app and then I get an error and then I have to refresh the app like scroll down again for it to rework (hot uk deals app) as an example. One or two other apps are also showing this issue.
Some website apps seem to be waiting to progress like vinted etc. But then it eventually progresses within the app to the next screen.
Strange thing is that these issues don’t occur outside the house on other WiFi connections. My browsing and surfing the net is absolutely fine like streaming etc but just certain apps seems to be playing up and I just can’t figure out why they are playing up when connected to the WiFi at home but not other places.
It’s a minor inconvenience which I can put up with but rather not put up with it. If you know what I mean when everything else is running quite good. The apps are all up to date as well. I am not at home right now so can’t check anything on the router but just don’t understand this issue. As this was never an issue before.
Another app I use is the nperf to do speed tests etc. That seems to run fine sometimes but then it just kicks up an error saying i need to restart the test. When I do the full speed test i notice the latency bit sometimes throws a few red I think it’s red or skipped options but other than that it works fine. But I don’t notice the latency issue not using a the home broadband. But the final results using this app shows all is good anyway. But I thought I throw that in here too.
Thoughts anyone?
Thoughts anyone?
