Where Has My Review Gone?
Last night I spent a fair amount of time keying in a review on my ISP, Supanet. I clicked 'submit' and my work promptly disappeared :confused:. There is not a substantial reward for its recovery;);).
What probably happened is that you spent so long writing the review that your login session expired, a lot like when you go to order a product on shopping sites and if you leave it too long before completing (i.e. go away to eat dinner) then the order doesn't go through and pushes you back to the front page or something similar.
Generally reviews should be kept short anyway as very few people will spend time reading a long one. The review system is supposed to have a check for the login session in case it expires but we've had a lot of difficulty in getting it to work correctly.
As the world's slowest typist, I used to find that sort of thing happening to me a lot - but there is a simple solution.
What I do nowadays, whether it be a message to the bank, my ISP, whatever - anything that's going in a box online - is knock it out offline as a plain text file first (i.e., if using Windows, use Notepad, not something with formatting like Wordpad or whatever) then copy and paste it into the box.
Yeah that's pretty much what I do for everything as well :) .
