Why Oh Why (CD boot problem)
I've had my PC for several years without any problems at all. After having decided (since it was spring) to do a wipe of my hard disk and a re-install of my Win XP I suddenly find that although I can read my CDs without any problem I cannot get the machine to boot from CD any more no matter how I adjust the Bios (ASUS) settings.
This is infuriating because I like to try out Linux distros in a dual boot system, but now I cannot any longer because I have to boot from the CD to get the Linux OS installed.
A curiosity, which may be linked, is that although I have two floppy drives the system insists that I have three which means that my CD is E instead of D. Could this have to do with the fact that since I was unable to boot my new Win XP CD to reinstall I had to go a long-winded way by first installing MSDOS 3.1, then Windows 3.1, then ME so that I could get Win XP setup to run? (both my copies of ME and Win XP are only upgrades).
I am confused as well as irritated. Obviously I have done something to upset the applecart, but what? I should be able to work out an answer but cannot. Humiliating it is but I am forced to turn to wiser souls in the computer community for ideas on how to put matters right again please.
If they are upgarde CDs then I dont think they are bootable.
See if you can get a copy of XP on CD, not an upgrade version.
However, I am not sure as to the legalities of this, although you have ( I assume) a legit copy of XP upgrade, I dont know if your licensed for the upgrade only or XP itself.
Old dude,
The Windows CDs are legitimate and I have had no problems in booting from them before when installing. It's nothing to do with the CDs.
Then its most likely your motherboard bios.
Could you disconnect one or both of the floppy drives for the duration of the install?
uch i cant believe some1 would go through that many windows upgrades...i wonder what % of performance u lose for doing that? Not to mention the time it would take...and as dos/win 3.1/win 9x (me) dont support NTFS u might end up just reformatting anyway to install XP.
AAAANNYYYWAY.
U need to make sure ur CD drive (regardless of drive letter) is in the boot sequence. Preferably as primary boot device for the duration of the install
