Wifi Antenna pattern
VWW
Does anyone know where I can find the WiFi antenna pattern of the TL-WPA7617? I'm trying to find if it is likely to be omni-directional, or have greater strength towards the 'front' of the antenna.
Not aware of a detailed design. Usually this detail is only provided on commercial units.
This is cheap CPE and therefore it will be invariably a simple printed antenna on the board. As it is a mains plug-in powerline there is likely to be internal screening for the components and interference. The mains socket and possibly the box will create further attenuation at the rear.
I don’t think I’ve ever known TP-Link to publish an antenna radiation plot for their consumer gear.
Their enterprise stuff (Omada) is a different matter, but that’s not much help here.
