this isnt my problem lm basically gathering information on an issue a friend has at the same time as contemplating whether its worth upgrading myself to the new version...
my friend upgraded to pre-n and is experiencing many disconnections.. in truth they wouldnt be noticeable if he was not on IRC however he keeps on dropping once every 5 mins on occasion, this used to be a problem when he was using bittorrent back then he was on the 802.11b/g one or the other but when he stopped using bittorrent for a week or two he was fine... altho at times he noticed then it was his cable modem causing issues... he has since upgraded to 802.11n (well pre-n) both hs router and reicever are version n however he keeps on dropping which like l said is only noticeable when we are on IRC (we run a IRC server remotely) so l was wondering if anyone knew any issues with that version of wireless (his hardware is made by belkin) from what l know his system is up to date with drivers and such he is using XP altho he does have vista on another patrician which sadly dosent support the hardware he has to connect to his router yet.
the fact is l wanna know more about his issue while seeing if there are issues and if its worth thinking about looking into a hardware upgrade lve been contemplating (which is mainly based on the distance and speed aspects of pre-n via wireless)
