nodrog
0
not sure if this should be here or in connections forum anyway
i have a netgear dg834g v3 54mbps router working with a wg111 usb adaptor but getting fed up with the velcro stick-up pad no longer working to hold adaptor at a good reception point and frequently having to repair connection as usb seems to freeze often and lose connection, thinking about getting pci adaptor instead
should i buy netgear wg311 54 mbps card or get the wg311t 108 mbps card which i presume will only work at the best it can recieve from router ie 54 mbps, my thinking is that the 108 would give me the option if i wanted to upgrage the modem / router to a 108 mbps at a later date
any opions would be aprreciated with thanks
