Work VPN dropout every 5 minutes Huawei B311s 3 mobile
DEXYBOY
Hi, struggling with my work VPN on 3 mobile with the 311s router. It used to be fine, maybe drop out every few days but for the last 3 months it drops out every 5 minutes or so. Basically I can run netflix etc fine and speed tests I get 40 down and 40 up but if I connect to my work VPN it bumps me off all the time. Not sure where to go, tried 3 support and the best they came up with was turn it off and on again, they were more clueless than me! I saw some people talking about trying different APNs.......not sure what that means?
If you log into your router you can see which APN you are using under Network Settings.
There or 2 to choose from. 3internet & three.co.uk
Is there a client app you use for the VPN connection eg Sonicwall Global VPN client for example? Sometimes the packet sizes cause problems with some ISP's, that client has a "Restrict the size of the first ASAKMP packet" which has fixed things for me in the past.
