Well my regrade, has been complete 3 days ago
from 300/50 to 900/120
Also about Ipv6 it will be disabled after regrade as the system gets reset and you need to be readded so email : ipv6@zen with your Login name zenxxxxxx@zen requesting you be reenabled to fix that..
Now you must make sure that you guys use proper download speed tests.
The popular ones @
fast.com *netflix*
speedtest.net
those are the 2 more popular but there crap.
and will report random speeds at all times of the day and make you think something is wrong with your speeds...
my recommendation is to test your speed from :
http://speedtest.tele2.net
download one of the http files for instance 100gb file takes me aprox : 15-17 minutes to download.. @ between 90-135mbs
also the fritx box they supply does support the speeds correclty.
im using though a asus rt-ac88u router as i need the extra features.
i will state though that i have a bt open reach engineer coming to my house on monday to do some diagnostics on my line as sometimes the speeds are erratic where by they wont constantly be downloading at there max they will fluctuate going up to there max then coming down and back up and back down instead of constantly maxing out..... hence why the bt guy will probably be doing a white light test to make sure my fiber cable is getting the optimal light exposure
never the less the speeds are fantastic i just hope in the future they can supply faster upload speeds.
